Visualize Normals
Get aligned points and vectors to preview the normal direction of any Honeybee geometry object the Rhino scene, including all sub-faces and assigned shades.
  • hb_objs [Required]
A Honeybee Model, Room, Face, Shade, Aperture, or Door for which points and vectors will be output in the Rhino scene to show the object's orientation.
  • points
Points that lie at the center of each surface of the connected _hb_objs. These should be connected to the "Anchor" input of a native Grasshopper "Vector Display" component.
  • vectors
Normal vectors for each surface of the connected _hb_objs. These should be connected to the "Vector" input of a native Grasshopper "Vector Display" component.
