Geometry Properties
Get geometry properties of honeybee Rooms or a honeybee Model.
  • rooms [Required]
A list of honeybee Rooms for which or geometry properties will be output. This can also be an entire honeybee Model.
  • ext_wall_area
A number for the total area of walls in the honeybee rooms with an Outdoors boundary condition (in Rhino model units).
  • ext_win_area
A number for the total area of windows in the honeybee rooms with an Outdoors boundary condition (in Rhino model units).
  • volume
A number for the volume of the honeybee rooms (in Rhino model units).
  • floor_area
A number for the floor area of the honeybee rooms (in Rhino model units). When a Model is connected, the floor area will exclude plenums and other Rooms with that have a True exclude_floor_area property.
  • floor_ep_constr
A number for the floor area of the Room accounting for the thickness of EnergyPlus wall constructions. (in Rhino model units). When a Model is connected, the floor area will exclude plenums and other Rooms with that have a True exclude_floor_area property.
