> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/honeybee-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/honeybee-primer/components/3_serialize/dump_objects.md).
# Dump Objects
![](https://3521261292-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1FZ8W_xSW4Nb61%2Fuploads%2Fgit-blob-449088cfe670eff406bb4760a604a78ffc6cf888%2FDump_Objects.png?alt=media)
![](https://3521261292-files.gitbook.io/~/files/v0/b/gitbook-legacy-files/o/assets%2F-LPHXQ1FZ8W_xSW4Nb61%2Fsync%2Fb8e16451bd425f1e824cdb3a382baca1c8c3ead4.png?generation=1621522944807790\&alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-core/blob/master/honeybee_grasshopper_core/src//HB%20Dump%20Objects.py)
Dump any honeybee object to a JSON file. You can use "HB Load Objects" component to load the objects from the file back into Grasshopper.
Honeybee objects include any honeybee energy Material, Construction, ConstructionSet, Schedule, Load, ProgramType, or Simulation object.
* **hb\_objs \[Required]**
A list of Honeybee objects to be written to a file.
* **name**
A name for the file to which the honeybee objects will be written. (Default: 'unnamed').
* **folder**
An optional directory into which the honeybee objects will be written. The default is set to the default simulation folder.
* **indent**
An optional positive integer to set the indentation used in the resulting JSON file.
* **abridged**
Set to "True" to serialize the object in its abridged form. Abridged objects cannot be reserialized back to honeybee objects on their own but they are used throughout honeybee to minimize file size and unnecessary duplication.
* **dump \[Required]**
Set to "True" to save the honeybee objects to file.
Errors, warnings, etc.
* **hb\_file**
The location of the file where the honeybee JSON is saved.
