> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/honeybee-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/honeybee-primer/components/0_create/skylights_by_ratio.md).
# Skylights by Ratio
![](https://3521261292-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1FZ8W_xSW4Nb61%2Fuploads%2Fgit-blob-09833248133ba7aee1d758cda150a2cdfd709f6a%2FSkylights_by_Ratio.png?alt=media)
![](https://3521261292-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1FZ8W_xSW4Nb61%2Fuploads%2Fgit-blob-8369467a07ccc516f3a6f020fcb94661c535123e%2FSkylights_by_Ratio.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-core/blob/master/honeybee_grasshopper_core/src//HB%20Skylights%20by%20Ratio.py)
Add skylight apertures to a Honeybee Face or Room given a ratio of aperture area to face area.
Note that this component will only add Apertures to Faces that are Roofs and have an Outdoors boundary condition.
* **hb\_objs \[Required]**
  A list of honeybee Rooms or Faces to which skylight Apertures will be added based on the inputs.&#x20;
* **ratio \[Required]**
  A number between 0 and 1 for the ratio between the area of the apertures and the area of the parent face.&#x20;
* **x\_dim**
  The x dimension of the grid cells as a number. (Default: 3 meters)&#x20;
* **y\_dim**
  The y dimension of the grid cells as a number. Default is None, which will assume the same cell dimension for y as is set for x.&#x20;
* **operable**
  An optional boolean to note whether the generated Apertures can be opened for ventilation. Default: False.&#x20;
* **hb\_objs**
  The input Honeybee Face or Room with skylight Apertures generated from the input parameters.&#x20;
