> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/honeybee-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/honeybee-primer/components/0_create/intersect_solids.md).
# Intersect Solids
![](https://3521261292-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1FZ8W_xSW4Nb61%2Fuploads%2Fgit-blob-eead3d69ee492a493cda1ff5ebbfa35d236d49d7%2FIntersect_Solids.png?alt=media)
![](https://3521261292-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1FZ8W_xSW4Nb61%2Fuploads%2Fgit-blob-6796a6cc23a1bd1600cb7f34c717484ae94ac294%2FIntersect_Solids.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-core/blob/master/honeybee_grasshopper_core/src//HB%20Intersect%20Solids.py)
Take a list of Honeybee Rooms closed breps (polysurfaces) and split their Faces to ensure that there are matching coplanar faces between them.
This matching between Room faces is required in order to contruct a correct multi-room energy model since conductive heat flow won't occur correctly across interior faces when their surface areas do not match.
* **rooms \[Required]**
A list of Honeybee Rooms or closed Rhino breps (polysurfaces) that do not have matching adjacent Faces.
* **cpu\_count**
* **run \[Required]**
* **int\_rooms**
The same input Rooms or closed breps that have had their component faces split by adjacent geometries to have matching surfaces.
