Dump Compressed Objects
Dump any honeybee object to a compressed .pkl file. You can use "HB Load Compressed Objects" component to load the objects from the file back into Grasshopper.
Honeybee objects include any Model, Room, Face, Aperture, Door, Shade, or boundary condition object
It also includes any honeybee energy Material, Construction, ConstructionSet, Schedule, Load, ProgramType, or Simulation object.
  • hb_objs [Required]
    A Honeybee object (or list of Honeybee objects) to be written to a file.
    A name for the file to which the honeybee objects will be written. (Default: 'unnamed').
  • folder
    An optional directory into which the honeybee objects will be written. The default is set to the default simulation folder.
  • dump [Required]
    Set to "True" to save the honeybee objects to file.
    Errors, warnings, etc.
  • hb_file
    The location of the file where the honeybee .pkl file is saved.
