Load gbXML OSM IDF
Load a gbXML, OSM, or IDF file as a Honeybee Model.
The reverse translators within the OpenStudio SDK are used to import all geometry and boundary conditions (including adjacencies) to a Honeybee format.
Note that, while all geometry will be imported, it is possible that not all of the properties assigned to this geometry will be imported, particularly if a certain property is not supported in the OpenStudio SDK. Honeybee will assign defaults for missing properites.
  • model_file [Required]
A file path to a gbXML, OSM or IDF file from which a Honeybee Model will be loaded.
  • reset_props
Set to True to have all energy properties reset to defaults upon import, meaning that only the geometry and boundary conditions are imported from the model file. (Default: False).
  • load [Required]
Set to "True" to load the Model from the input file.
  • model
A honeybee Model objects that has been re-serialized from the input file.
