# Page Not Found
The URL `components/3_serialize/load_gbxml` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Dump gbXML](https://docs.ladybug.tools/honeybee-primer/components/3_serialize/dump_gbxml.md)
- [Load gbXML OSM IDF](https://docs.ladybug.tools/honeybee-primer/components/3_serialize/load_gbxml_osm_idf.md)
- [Load Objects](https://docs.ladybug.tools/honeybee-primer/components/3_serialize/load_objects.md)
- [Validate Model](https://docs.ladybug.tools/honeybee-primer/components/3_serialize/validate_model.md)
- [Update HBJSON](https://docs.ladybug.tools/honeybee-primer/components/3_serialize/update_hbjson.md)
GET https://docs.ladybug.tools/honeybee-primer/components/3_serialize/dump_gbxml.md?ask=<question>&goal=<user_goal>
Full index: https://docs.ladybug.tools/honeybee-primer/sitemap.md
Full export: https://docs.ladybug.tools/honeybee-primer/llms-full.txt
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/honeybee-primer/components/3_serialize/dump_gbxml.md`).
