# Page Not Found
The URL `components/4_alternativeweather/write_ddy` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Write DDY](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/write_ddy.md)
- [Write EPW](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/write_epw.md)
- [Create EPW](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/create_epw.md)
- [Construct Design Day](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/construct_design_day.md)
- [Terrain](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/terrain.md)
GET https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/write_ddy.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/dragonfly-primer/components/6_alternativeweather/write_ddy.md`).
