Detailed Windows
Add detailed window geometries to Dragonfly Room2Ds.
  • df_objs [Required]
A Dragonfly Model, Building, Story or Room2D, to which the _windows should be added.
  • windows [Required]
A list of Breps that will be added to the input _df_objs as detailed windows. This can also be a list of orphaned Honeybee Apertures and/or Doors to be added to the Dragonfly objects. In the case of Doors, they will be assigned to the Dragonfly object as such.
  • project_dist
An optional number to be used to project the Aperture/Door geometry onto parent Faces. If specified, then sub-faces within this distance of the parent Face will be projected and added. Otherwise, Apertures/Doors will only be added if they are coplanar with a parent Face.
  • df_objs
The input dragonfly objects with the input _windows added to it.
