Load Objects
Load any dragonfly object from a dragonfly JSON file
This includes any Model, Building, Story, Room2D, WindowParameter, or ShadingParameter.
It also includes any energy Material, Construction, ConstructionSet, Schedule, Load, ProgramType, or Simulation object.
  • df_file [Required]
A file path to a dragonfly JSON (or DFJSON representing a full dragonfly Model) from which objects will be loaded into Grasshopper. This can also be the path to a Pollination Model Format (.POMF) file from which a dragonfly Model will be loaded. Note that, if the objects in the JSON are not a full model, they must be non-abridged in order to be loaded correctly.
  • load [Required]
Set to "True to load the objects from the _df_file.
  • df_objs
A list of dragonfly objects that have been re-serialized from the input file.
