Single Window Parameters
Create Dragonfly window parameters with instructions for a single window in the face center defined by a width and height.
Note that, if these parameters are applied to a base face that is too short or too narrow for the input width and/or height, the generated window will automatically be shortened when it is applied to the face. In this way, setting the width to be a very high number will create parameters that always generate a ribboin window of the input height.
  • width [Required]
    A number for the window width.
  • height [Required]
    A number for the window height.
  • sill_height
    A number for the window sill height. Default: 0.8 meters.
  • win_par
    Window Parameters that can be applied to a Dragonfly object using the "DF Apply Facade Parameters" component.
