Deconstruct All Object
Deconstruct any Dragonfly geometry object into ALL of its constituent Dragonfly objects.
This is useful for editing auto-generated child objects separately from their parent. For example, if you want to assign all of the ground floors of a given auto-generated Building to have a Retail ProgramType, this can give you all of such Stories. Then you can assign a Retail ProgramType to them and combine them with the other Stories into a new Building.
  • df_obj [Required]
    A Dragonfly Building, Story or Room2D to be deconstructed into all of its constituent objects. Note that, Room2Ds do not have sub-objects assigned to them and the original object will be output.
  • all_stories
    Script variable Python
  • all_room2ds
