Detailed HVAC
Apply a detailed Ironbug HVAC to Dragonfly Buildings, Stories or Room2Ds.
  • df_objs [Required]
Dragonfly Buildings, Stories or Room2Ds to which the input Ironbug HVAC will be assigned. This can also be an etire dragonfly Model. Only the relevant Room2Ds referenced in the _hvac_system will be assigned the HVAC system.
  • hvac_system [Required]
A fully-detailed Irongbug HVAC system to be assigned to the input dragonfly objects.
Text to set the name for the HVAC system and to be incorporated into unique HVAC identifier. If the name is not provided, a random name will be assigned.
  • df_objs
The input Rooms or Model with the detailed HVAC system applied.
