REopt Financial Parameters
Customize the financial settings of a REopt analysis.
  • years
An integer for the number of years over which cost will be optimized. (Default: 25).
  • escalation
A number between 0 and 1 for the escalation rate over the analysis. (Default: 0.023).
  • tax
A number between 0 and 1 for the rate at which the owner/host of the system is taxed. (Default: 0.26).
  • discount
A number between 0 and 1 for the discount rate for the owner/host of the system. (Default: 0.083).
  • wind_cost
A number for the installation cost of wind power in US dollars per kW. (Default: 3013).
  • pv_cost
A number for the installation cost of photovoltaic power in US dollars per kW. (Default: 1600).
  • pv_grnd_cost
A number for the installation cost of photovoltaic power in US dollars per kW. (Default: 2200).
  • storage_cost
A number for the installation cost of power storage in US dollars per kW. (Default: 840).
  • gener_cost
A number for the installation cost of generators in US dollars per kW. (Default: 500).
  • financial_par
A REoptParameter object that can be plugged into the 'DF Run REopt' component.
