Write EPW
Write an EPW object into a .epw file.
epw_obj [Required]
An EPW object such as that exported from the Create EPW component.
folder
A directory into which the .epw file will be written.
file_name
An optional name for the .epw file. Default will use the city of the EPW object's location.
run [Required]
Set to True to run the component and write the .epw file.
report
epw_file
File path to a .epw that contains all of the data in the input _epw_obj.
