Set Ground Top
Set Room2Ds or Stories to have their floor in contact with the ground or their roofs in contact with the outdoors.
  • df_obj [Required]
    Dragonfly Stories or Room2Ds which will have its floor set to be in contact with the ground or its roof to be in contact with the outdoors.
  • grnd_contact
    A boolean noting whether the input objects have floors in contact with the ground.
  • top_exposed
    A boolean noting whether the input objects have ceilings exposed to the outdoors.
  • df_obj
    The input Dragonfly object with its ground_contact or top_exposed properties edited.
