Dragonfly Primer
Ladybug Tools for Grasshopper Documentation
  • Dragonfly Primer
  • Components
    • 0 :: Create
      • Deconstruct All Object
      • Deconstruct Model
      • Deconstruct Object
      • Model
      • Building from Detailed Rooms
      • Building from Footprint
      • Building from Solid
      • Building from Stories
      • Process Alleys
      • Separate Top Bottom
      • Rejoin to Building
      • Story
      • Room2D
      • Solve Adjacency
      • Apply Facade Parameters
      • Detailed Windows
      • Repeating Window Ratio Parameters
      • Repeating Window Width Height Parameters
      • Simple Window Ratio Parameters
      • Single Window Parameters
      • Extruded Border Parameters
      • Gridded Skylight Parameters
      • Louver Parameters
      • Overhang Parameters
      • Apply Roof
      • ContextShade
      • Align
      • BC by Orientation
      • Deconstruct Roof
      • Intersect Room2Ds
      • Set Ground Top
    • 1 :: Visualize
      • Visualize All
      • Visualize Floors
      • Visualize Quick
      • Visualize Wireframe
      • Geometry Properties
      • Room2D Attributes
      • Color Room2D Attributes
      • Room2Ds by Attribute
      • Color Network Attributes
      • Network Attributes
      • Color Network Results
    • 2 :: Serialize
      • Object to String
      • String to Object
      • Dump Objects
      • Load Objects
      • Model To Honeybee
      • Model To geoJSON
      • Model From Honeybee
      • Model From geoJSON
      • Validate Model
    • 3 :: Energy
      • Run OpenDSS
      • Run REopt
      • Run RNM
      • Run URBANopt
      • Diversify Building Programs
      • Load Mapper Measure
      • Process Load
      • Reassign Energy Properties
      • All-Air HVAC
      • DOAS HVAC
      • Detailed HVAC
      • HeatCool HVAC
      • IdealAir
      • SHW System
      • Electrical Connector
      • Electrical Network
      • Ground Photovoltaics
      • Road Network
      • Substation
      • Transformer
      • Read OpenDSS Result
      • Search OpenDSS
      • Deconstruct OpenDSS
      • Fourth Generation Thermal Loop
      • GHE Thermal Loop
      • REopt Financial Parameters
      • Run Modelica DES
      • Window Opening
    • 4 :: AlternativeWeather
      • Run Urban Weather Generator
      • UWG Simulation Parameter
      • Assign Building UWG Properties
      • Assign Model UWG Properties
      • Terrain
      • Traffic Parameters
      • Construct Design Day
      • Create EPW
      • Write DDY
      • Write EPW
      • Horizontal Infrared
      • Import NOAA File
      • Boundary Layer Parameters
      • Luminous Efficacy
      • Reference EPW Parameters
      • Vegetation Parameters
Powered by GitBook
On this page
  • Inputs
  • Outputs
Export as PDF
  1. Components
  2. 4 :: AlternativeWeather
PreviousRun Urban Weather GeneratorNextAssign Building UWG Properties
Last updated 1 year ago
Create a simulation parameter object that carries a complete set of Urban Weather Genreator (UWG) simulation settings and can be plugged into the "DF Run Urban Weather Generator" component.
  • run_period
A Ladybug Analysis Period object to describe the time period over which to run the simulation. If None, the simulation will be run for the whole year.
  • timestep
An integer for the number of timesteps per hour at which the calculation will be run. (Default: 12).
  • veg_par
A VegetationParameter object to specify the behavior of vegetation in the urban area. If None, generic vegetation parameters will be generated.
  • epw_site
A ReferenceEPWSite object to specify the properties of the reference site where the input rural EPW was recorded. If None, generic airport properties will be generated.
  • bnd_layer
A BoundaryLayerParameter to specify the properties of the urban boundary layer. If None, generic boundary layer parameters will be generated.
  • sim_par
A UWG SimulationParameter object that can be connected to the "DF Run Urban Weather Generator" component in order to specify UWG simulation settings
[source code]
