# Page Not Found
The URL `components/4_alternativeweather/assign_model_uwg_properties` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Assign Model UWG Properties](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/assign_model_uwg_properties.md)
- [Assign Building UWG Properties](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/assign_building_uwg_properties.md)
- [Reassign Energy Properties](https://docs.ladybug.tools/dragonfly-primer/components/3_energy/reassign_energy_properties.md)
- [UWG Simulation Parameter](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/uwg_simulation_parameter.md)
- [Boundary Layer Parameters](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/boundary_layer_parameters.md)
GET https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/assign_model_uwg_properties.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/dragonfly-primer/components/6_alternativeweather/assign_model_uwg_properties.md`).
