# Page Not Found
The URL `components/4_alternativeweather/vegetation_parameters` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Vegetation Parameters](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/vegetation_parameters.md)
- [Traffic Parameters](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/traffic_parameters.md)
- [UWG Simulation Parameter](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/uwg_simulation_parameter.md)
- [Reference EPW Parameters](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/reference_epw_parameters.md)
- [Boundary Layer Parameters](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/boundary_layer_parameters.md)
GET https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/vegetation_parameters.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/dragonfly-primer/components/6_alternativeweather/vegetation_parameters.md`).
