# Page Not Found
The URL `components/3_energy/run_rnm` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Run RNM](https://docs.ladybug.tools/dragonfly-primer/components/4_electricgrid/run_rnm.md)
- [Run REopt](https://docs.ladybug.tools/dragonfly-primer/components/3_energy/run_reopt.md)
- [Run URBANopt](https://docs.ladybug.tools/dragonfly-primer/components/3_energy/run_urbanopt.md)
- [3 :: Energy](https://docs.ladybug.tools/dragonfly-primer/components/3_energy.md)
- [SHW System](https://docs.ladybug.tools/dragonfly-primer/components/3_energy/shw_system.md)
GET https://docs.ladybug.tools/dragonfly-primer/components/4_electricgrid/run_rnm.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/dragonfly-primer/components/4_electricgrid/run_rnm.md`).
