Dragonfly Primer
Ladybug Tools for Grasshopper Documentation
  • Dragonfly Primer
  • Components
    • 0 :: Create
      • Deconstruct All Object
      • Deconstruct Model
      • Deconstruct Object
      • Model
      • Building from Detailed Rooms
      • Building from Footprint
      • Building from Solid
      • Building from Stories
      • Process Alleys
      • Separate Top Bottom
      • Rejoin to Building
      • Story
      • Room2D
      • Solve Adjacency
      • Apply Facade Parameters
      • Detailed Windows
      • Repeating Window Ratio Parameters
      • Repeating Window Width Height Parameters
      • Simple Window Ratio Parameters
      • Single Window Parameters
      • Extruded Border Parameters
      • Gridded Skylight Parameters
      • Louver Parameters
      • Overhang Parameters
      • Apply Roof
      • ContextShade
      • Align
      • BC by Orientation
      • Deconstruct Roof
      • Intersect Room2Ds
      • Set Ground Top
    • 1 :: Visualize
      • Visualize All
      • Visualize Floors
      • Visualize Quick
      • Visualize Wireframe
      • Geometry Properties
      • Room2D Attributes
      • Color Room2D Attributes
      • Room2Ds by Attribute
      • Color Network Attributes
      • Network Attributes
      • Color Network Results
    • 2 :: Serialize
      • Object to String
      • String to Object
      • Dump Objects
      • Load Objects
      • Model To Honeybee
      • Model To geoJSON
      • Model From Honeybee
      • Model From geoJSON
      • Validate Model
    • 3 :: Energy
      • Run OpenDSS
      • Run REopt
      • Run RNM
      • Run URBANopt
      • Diversify Building Programs
      • Load Mapper Measure
      • Process Load
      • Reassign Energy Properties
      • All-Air HVAC
      • DOAS HVAC
      • Detailed HVAC
      • HeatCool HVAC
      • IdealAir
      • SHW System
      • Electrical Connector
      • Electrical Network
      • Ground Photovoltaics
      • Road Network
      • Substation
      • Transformer
      • Read OpenDSS Result
      • Search OpenDSS
      • Deconstruct OpenDSS
      • Fourth Generation Thermal Loop
      • GHE Thermal Loop
      • REopt Financial Parameters
      • Run Modelica DES
      • Window Opening
    • 4 :: AlternativeWeather
      • Run Urban Weather Generator
      • UWG Simulation Parameter
      • Assign Building UWG Properties
      • Assign Model UWG Properties
      • Terrain
      • Traffic Parameters
      • Construct Design Day
      • Create EPW
      • Write DDY
      • Write EPW
      • Horizontal Infrared
      • Import NOAA File
      • Boundary Layer Parameters
      • Luminous Efficacy
      • Reference EPW Parameters
      • Vegetation Parameters
Powered by GitBook
On this page
  • Inputs
  • Outputs
Export as PDF
  1. Components
  2. 3 :: Energy
Read OpenDSS Result
PreviousTransformerNextSearch OpenDSS
Last updated 3 years ago
Parse any CSV file output from an OpenDSS simulation.
  • dss_csv [Required]
    The file path of any CSV result file that has been generated from an OpenDSS simulation. This can be either a Building CSV with voltage information or transformers/connectors with loading information.
  • factors
    A list of data collections containing the dimensionless fractional values from the CSV results. For buildings, these represent the voltage at a given timestep divided by the standard outlet voltage (120 V). For transformers and connectors, these represent the power along the wire or transformer divided by the kVA rating of the object.
  • condition
    A list of data collections noting the condition of a given object. For example, whether the object is over or under voltage (in the case of a building) or whether it is overloaded (in the case of a transformer or electrical connector).
[source code]
