> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/dragonfly-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/dragonfly-primer/components/2_serialize/model_from_geojson.md).
# Model From geoJSON
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-2c35c54d46f30334c1d58a176a2c68b2d68578ba%2FModel_From_geoJSON.png?alt=media)
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-2b9aa138cf0b1db0553fa7861e649452f095ba82%2FModel_From_geoJSON.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/dragonfly-grasshopper/blob/master/dragonfly_grasshopper/src//DF%20Model%20From%20geoJSON.py)
Create a Dragonfly Model from a geoJSON file.
* **geojson \[Required]**
  Text for the full path to a geojson file to be loaded as a Dragonfly Model.&#x20;
* **point**
  An optional Point for where the bottom-left corner of the bounding rectangle around all of the geoJSON building footprints exists within the Rhino scene. (Default: (0, 0), the Rhino origin).&#x20;
* **all\_to\_bldg**
  Boolean to indicate if all polygon and multi-polygon geometries in the geojson file should be considered Buildings. If False or unspecified, this component will only generate Dragonfly Buildings from geometries that are defined as a 'Building' in the 'type' field of the 'properties' field of each geoJSON feature. Note that this 'type' field is not a universal convention of all geoJSONs. However, all Dragonfly-expored geoJSONs will have it and all URBANopt-compatible geoJSONs will also have it.&#x20;
* **other\_geo**
  Boolean to indicate whether geometry that is not identified as a dragonfly Building should be imported. For large geoJSONs, this can potentially increase the component runtime a lot but this geometry may be useful for constructing other important features like context or electical networks.&#x20;
* **import \[Required]**
  Set to "True" to import the geoJSON as a Dragonfly Model.&#x20;
* **model**
  A Dragonfly Model object derived from the input geoJSON.&#x20;
* **other\_geo**
  Other non-building line segment and polygon data contained within the geoJSON. Will be None unless other*geo* is set to True.&#x20;
* **location**
  A ladybug Location object possessing longitude and lattiude data used to position geoJSON file on the globe.&#x20;
* **point**
  A Point for where the \_location object exists within the space of the Rhino scene. This is can be used to re-position the geoJSON file on the globe when re-exporting the Dragonfly Model to geoJSON.&#x20;
