Building from Solid
Create Dragonfly Buildings from solid geometry (closed Rhino polysurfaces).
  • bldg_geo [Required]
    A list of closed Rhino polysurfaces to be converted into Buildings.
  • floor_to_floor [Required]
    An array of floor-to-floor height instructions that describe how a building mass should be divided into floors. The array should run from bottom floor to top floor. Each item in the array can be either a single number for the floor-to-floor height or a text string that codes for how many floors of each height should be generated. For example, inputting "2@4" will make two floors with a height of 4 units. Simply inputting "@3" will make all floors at 3 units. Putting in sequential arrays of these text strings will divide up floors accordingly. For example, the list ["1@5", "2@4", "@3"] will make a ground floor of 5 units, two floors above that at 4 units and all remaining floors at 3 units.
  • perim_offset
    An optional positive number that will be used to offset the perimeter of the footprint to create core/perimeter Rooms. If this value is None or 0, no offset will occur and each floor plate will be represented with a single Room2D.
    Text to set the base name for the Building, which will also be incorporated into unique Building identifier. This will be combined with the index of each input _bldg_geo to yield a unique name for each output Building. If the name is not provided, a random one will be assigned.
  • program
    Text for the program of the Buildings (to be looked up in the ProgramType library) such as that output from the "HB List Programs" component. This can also be a custom ProgramType object. If no program is input here, the Buildings will have a generic office program.
  • constr_set
    Text for the construction set of the Buildings, which is used to assign all default energy constructions needed to create an energy model. Text should refer to a ConstructionSet within the library such as that output from the "HB List Construction Sets" component. This can also be a custom ConstructionSet object. If nothing is input here, the Buildings will have a generic construction set that is not sensitive to the Buildings's climate or building energy code.
  • conditioned
    Boolean to note whether the Buildings have heating and cooling systems.
  • run [Required]
    Set to True to run the component and create Dragonfly Buildings.
  • buildings
    Dragonfly buildings.
