> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/dragonfly-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/dragonfly-primer/components/3_energy/ground_photovoltaics.md).
# Ground Photovoltaics
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-c0ca367ef661b902fa285a760bf9e083657e2604%2FGround_Photovoltaics.png?alt=media)
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-a207f02e7c089df4668283f2d19b75768cd68392%2FGround_Photovoltaics.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/dragonfly-grasshopper/blob/master/dragonfly_grasshopper/src//DF%20Ground%20Photovoltaics.py)
Create a REopt ground-mounted photovoltaic system from its footprint geometry (horizontal Rhino surfaces).
* **geo \[Required]**
A horizontal Rhino surface (or closed polyline) representing a footprint to be converted into a ground-mounted photovoltaic system.
* **name**
Text to set the name for the PV system, which will also be incorporated into unique PV system identifier. If the name is not provided, a random one will be assigned.
* **bldg**
An optional Dragonfly Building with which the photovoltaic system is associated. If None, the PV system will be assumed to be a community PV field that isn't associated with a particular building meter.
* **ground\_pv**
A Dragonfly ground-mounted PV system object that can be exported to a GeoJSON in order to account for ground-mounted photovoltaics in a REopt simulation.
