Overhang Parameters
Create Dragonfly shading parameters with instructions for a single overhang (awning, balcony, etc.) over an entire wall.
  • depth [Required]
    A number for the overhang depth.
  • angle
    A number for the for an angle to rotate the overhang in degrees. Default is 0 for no rotation.
  • shd_par
    Shading Parameters that can be applied to a Dragonfly object using the "DF Apply Facade Parameters" component.
