# Page Not Found
The URL `components/3_energy/electrical_connector` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Electrical Connector](https://docs.ladybug.tools/dragonfly-primer/components/4_electricgrid/electrical_connector.md)
- [Electrical Network](https://docs.ladybug.tools/dragonfly-primer/components/4_electricgrid/electrical_network.md)
- [REopt Financial Parameters](https://docs.ladybug.tools/dragonfly-primer/components/3_energy/reopt_financial_parameters.md)
- [Detailed HVAC](https://docs.ladybug.tools/dragonfly-primer/components/3_energy/detailed_hvac.md)
- [HeatCool HVAC](https://docs.ladybug.tools/dragonfly-primer/components/3_energy/heatcool_hvac.md)
GET https://docs.ladybug.tools/dragonfly-primer/components/4_electricgrid/electrical_connector.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/dragonfly-primer/components/4_electricgrid/electrical_connector.md`).
