Set Plenums
Set the ceiling plenum and/or floor plenum depth of rooms for any Dragonfly object (Room2Ds, Stories, Buildings, Model).
  • df_obj [Required]
A Dragonfly Model, Building, Story or Room2D to have plenum depths assigned to it.
  • ceil_plenum
A number for the depth that ceiling plenums extend into rooms. Setting this to a positive value will result in a separate plenum room being split off of the Room2D volume during translation from Dragonfly to Honeybee.
  • floor_plenum
A number for the depth that floor plenums extend into rooms. Setting this to a positive value will result in a separate plenum room being split off of the Room2D volume during translation from Dragonfly to Honeybee.
  • df_obj
The input Dragonfly object with ceiling or floor plenum depths set.
