GHE Pipe Parameter
Create a PipeParameter object that can be used to customize the pipe properties within a Ground Heat Exchanger (GHE) sizing simulation.
The output of this component can be used with either the "DF GHE Designer" component or the "DF GHE Thermal Loop" component.
  • inner_diameter
A number in Rhino model units (eg. Meters, Feet, etc.) for the diameter of the inner pipe surface in meters. (Default: 0.0216 meters).
  • outer_diameter
A number in Rhino model units (eg. Meters, Feet, etc.) for the diameter of the outer pipe surface in meters. (Default: 0.0266 meters).
  • shank_spacing
A number in Rhino model units (eg. Meters, Feet, etc.) for the spacing between the U-tube legs, as referenced from outer surface of the pipes in meters. (NOT referenced from each pipe's respective centerline). (Default: 0.0323 meters).
  • conductivity
A number for the conductivity of the pipe material in W/m-K. (Default: 0.4).
  • heat_capacity
A number for the volumetric heat capacity of the pipe material in J/m3-K. (Default: 1,542,000).
  • arrangement
Text for the specified pipe arrangement. Choose from the following options. (Default: SingleUTube).
  • pipe
A PipeParameter object that can be plugged into the "DF GHE Designer" component in order to customize pipe properties of a GHE sizing simulation. It can also be plugged into the "DF GHE Thermal Loop" component to perform a similar role in a District Energy Simulation (DES) of a loop with a ground heat exchanger.
