> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/dragonfly-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/dragonfly-primer/components/0_create/join_small_rooms.md).
# Join Small Rooms
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-d5fb04f188bee85dfc19233ef5030a551c45162c%2FJoin_Small_Rooms.png?alt=media)
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-859be898f82b19a38f8fc6e317335e016f999b70%2FJoin_Small_Rooms.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/dragonfly-grasshopper/blob/master/dragonfly_grasshopper/src//DF%20Join%20Small%20Rooms.py)
Join small Room2Ds together within Dragonfly Stories.
This is particularly useful after operations like automatic core/perimeter offsetting, which can create several small Room2Ds from small segments in the outline boundary around the Story.
* **df\_obj \[Required]**
A Dregonfly Story, Building or Model to have its small Room2Ds joined together across the model
* **area\_thresh**
A number for the Room2D floor area below which it is considered a small room to be joined into adjacent rooms. (Default: 10.0 square meters).
* **join\_to\_large**
A boolean to note whether the small Room2Ds should be joined into neighboring large Room2Ds as opposed to simply joining the small rooms to one another. (Default: False).
* **df\_obj**
The input Dragonfly objects with Room2Ds that have had small Room2Ds joined together.
