Run Modelica
Run a Modelica District Energy System (DES) through an annual simulation using OpenModelica inside a Docker image (via Docker Desktop).
Docker Dekstop can be downloaded at the following link: https://www.docker.com/products/docker-desktop/
  • modelica [Required]
A folder where all of the Modelica files of the District Energy System (DES) are written. These Modelica files can be created using the "DF Write Modelica DES" component.
  • run [Required]
Script variable Python
  • results
A folder containing the results of the Modelica simulation.
