> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/ladybug-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/ladybug-primer/components/0_import/construct_location.md).
# Construct Location
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-402c3e1d74670e5a208febe55d36e19b65085c94%2FConstruct_Location.png?alt=media)
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-a1d3569586f8c712e91c15bb8eb6c882252acb65%2FConstruct_Location.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/ladybug-grasshopper/blob/master/ladybug_grasshopper/src//LB%20Construct%20Location.py)
Construct location from latitude, lognitude, and time zone data.
* **name**
A name for the location you are constructing. For example, "Steventon Island, Antarctica". (Default: "-")
* **latitude**
Location latitude between -90 and 90 (Default: 0).
* **longitude**
Location longitude between -180 (west) and 180 (east) (Default: 0).
* **time\_zone**
Time zone between -12 hours (west) and 12 hours (east). If None, the time zone will be an estimated integer value derived from the longitude in accordance with solar time (Default: None).
* **elevation**
A number for elevation of the location in meters. (Default: 0).
* **location**
Location data (use this output to construct the sun path).
