> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/ladybug-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/ladybug-primer/components/0_import/import_design_day.md).
# Import Design Day
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-3d37680470ec38e9a5d7bf0bcfb5730f325cb230%2FImport_Design_Day.png?alt=media)
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-a6e7acc42e283d075defcc2384c86e56904977a7%2FImport_Design_Day.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/ladybug-grasshopper/blob/master/ladybug_grasshopper/src//LB%20Import%20Design%20Day.py)
Import hourly climate data from a Ladybug DesignDay object.
* **design\_day \[Required]**
A DesignDay object to import.
* **location**
A Ladybug Location object describing the location of the design day.
* **dry\_bulb\_temperature**
The houlry dry bulb temperature over the design day, in C.
* **dew\_point\_temperature**
The hourly dew point temperature over the design day, in C.
* **relative\_humidity**
The hourly Relative Humidity over the design day in percent.
* **wind\_speed**
The hourly wind speed over the design day in m/sec.
* **wind\_direction**
The hourly wind direction over the design day in degrees. The convention is that North=0.0, East=90.0, South=180.0, West=270.0.
* **direct\_normal\_rad**
The hourly Direct Normal Radiation over the design day in Wh/m2.
* **diffuse\_horizontal\_rad**
The hourly Diffuse Horizontal Radiation over the design day in Wh/m2.
* **global\_horizontal\_rad**
The hourly Global Horizontal Radiation over the design day in Wh/m2.
* **horizontal\_infrared\_rad**
The Horizontal Infrared Radiation Intensity over the design day in Wh/m2.
* **total\_sky\_cover**
The fraction for total sky cover over the design day in tenths of coverage.
* **barometric\_pressure**
The hourly weather station pressure over the design day in Pa.
