> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/ladybug-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/ladybug-primer/components/1_analyzedata/degree_days.md).
# Degree Days
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-103df500343c467f0798b59598976103f2ff4b50%2FDegree_Days.png?alt=media)
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-5998fa8dd35981231d3b40f5da46078b6e8e5b29%2FDegree_Days.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/ladybug-grasshopper/blob/master/ladybug_grasshopper/src//LB%20Degree%20Days.py)
Calculate heating and cooling degree-days from outdoor dry bulb temperature.
* **dry\_bulb \[Required]**
A data collection representing outdoor dry bulb temperature \[C]
* **heat\_base**
A number for the base temperature below which a given hour is considered to be in heating mode. Default is 18 Celcius, which is a common balance point for buildings.
* **cool\_base**
A number for the base temperature above which a given hour is considered to be in cooling mode. Default is 23 Celcius, which is a common balance point for buildings.
* **hourly\_heat**
A data collection of heating degree-days. Plug this into the 'Time Interval Operation' component to get the number of degree-days at different time intervals.
* **hourly\_cool**
A data collection of cooling degree-days. Plug this into the 'Time Interval Operation' component to get the number of degree-days at different time intervals.
* **heat\_deg\_days**
A value indicating the total number of heating degree-days over the entire input \_dry\_bulb collection.
* **cool\_deg\_days**
A value indicating the total number of cooling degree-days over the entire input \_dry\_bulb collection.
