> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/ladybug-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/ladybug-primer/components/1_analyzedata/time_interval_operation.md).
# Time Interval Operation
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-12d64099e3c341fb6e902e1d3d8e26bf1f9f9f6b%2FTime_Interval_Operation.png?alt=media)
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-43a675f112f357ffcbc402bf481aa55ce0e8e726%2FTime_Interval_Operation.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/ladybug-grasshopper/blob/master/ladybug_grasshopper/src//LB%20Time%20Interval%20Operation.py)
Perform time interval operations on an hourly data collection.
This includes operations like: - Average - Total - Percentile
These actions can be performed over the following time intervals: - Daily - Monthly - Monthly per Hour
* **data \[Required]**
A Ladybug data collection object.
* **operation**
Text indicating the operation that should be performed on the input hourly data. Such text must be one of the following:
- average
- total
- [a number between 0 and 100]
In the case of the last option, the number will be interpreted as a percentile of the data over the time period. For example, inputting 75 will return the 75th percentile value of each day/month/hour, inputting 0 will give the minimum value of each day/month/hour and inputting 100 will give the max value of each day/month/hour. Default is 'average' if the input data type is not cumulative and 'total' if the data type is cumulative.
* **daily**
Daily data collection derived from the input \_data and *operation*.
* **monthly**
Monthly data collection derived from the input \_data and *operation*.
* **mon\_per\_hr**
Monthly Per Hour data collection derived from the input \_data and *operation*.
