> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/ladybug-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/ladybug-primer/components/1_analyzedata/convert_to_timestep.md).
# Convert to Timestep
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-5b6f8c7199f376d4a49931f3e3b6ec099a78560a%2FConvert_to_Timestep.png?alt=media)
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-b0eaade24e08015364b7700ca304b22f12e9dbe8%2FConvert_to_Timestep.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/ladybug-grasshopper/blob/master/ladybug_grasshopper/src//LB%20Convert%20to%20Timestep.py)
Convert a hourly Ladybug data collection to a continuous collection at a specific timestep.
This will be done either through linear interpolation or by culling out values that do not fit the timestep. It can also be used to convert a discontinous data collection to a continuous one by linearly interpolating over holes in the data set.
* **data \[Required]**
A Ladybug Hourly DataCollection object. This can be either continuous or discontinuous.
* **timestep**
The timestep to which the data will be converted. If this is higher than the input \_data timestep, values will be linerarly interpolated to the new timestep. If it is lower, values that do not fit the timestep will be removed from the DataCollection. (Defaut: 1)
* **data**
A Continuous DataCollection at the input *timestep*.
