> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/ladybug-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/ladybug-primer/components/1_analyzedata/construct_header.md).
# Construct Header
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-96ecaf7f91de3bb594045d33e599051fc6e3e1e0%2FConstruct_Header.png?alt=media)
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-7f56aae2a403bf03574933456c3c6a391341d95d%2FConstruct_Header.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/ladybug-grasshopper/blob/master/ladybug_grasshopper/src//LB%20Construct%20Header.py)
Construct a Ladybug Header to be used to create a ladybug DataCollection.
* **data\_type \[Required]**
Text representing the type of data (e.g. Temperature). A full list of acceptable inputs can be seen by checking the all\_u output of the "LB Unit Converter" component. This input can also be a custom DataType object that has been created with the "LB Construct Data Type" component.
* **unit**
Units of the data\_type (e.g. C). Default is to use the base unit of the connected\_data\_type.
* **a\_period**
Script variable constrData
* **metadata**
Optional metadata to be associated with the Header. The input should be a list of text strings with a property name and value for the property separated by a colon. For example: . source: TMY . city: New York . country: USA
* **header**
A Ladybug Header object.
