Incident Radiation
Calculate the incident radiation on geometry using a sky matrix from the "Cumulative Sky Matrix" component.
Such studies of incident radiation can be used to apprxomiate the energy that can be collected from photovoltaic or solar thermal systems. They are also useful for evaluating the impact of a building's orientation on both energy use and the size/cost of cooling systems. For studies of photovoltaic potential or building energy use impact, a sky matrix from EPW radiation should be used. For studies of cooling system size/cost, a sky matrix derived from the STAT file's clear sky radiation should be used.
NOTE THAT NO REFLECTIONS OF SOLAR ENERGY ARE INCLUDED IN THE ANALYSIS PERFORMED BY THIS COMPONENT.
Ground reflected irradiance is crudely acounted for by means of an emissive "ground hemisphere," which is like the sky dome hemisphere and is derived from the ground reflectance that is associated with the connected _sky_mtx. This means that including geometry that represents the ground surface will effectively block such crude ground reflection.
Also note that this component uses the CAD environment's ray intersection methods, which can be fast for geometries with low complexity but does not scale well for complex geometries or many test points. For such complex cases and situations where relfection of solar energy are important, honeybee-radiance should be used.
  • sky_mtx [Required]
A Sky Matrix from the "LB Cumulative Sky Matrix" component or the "LB Benefit Sky Matrix" component, which describes the radiation coming from the various patches of the sky. The "LB Sky Dome" component can be used to visualize any sky matrix to understand its relationship to the test geometry.
  • geometry [Required]
Rhino Breps and/or Rhino Meshes for which incident radiation analysis will be conducted. If Breps are input, they will be subdivided using the _grid_size to yeild individual points at which analysis will occur. If a Mesh is input, radiation analysis analysis will be performed for each face of this mesh instead of subdividing it.
  • context
Rhino Breps and/or Rhino Meshes representing context geometry that can block solar radiation to the test _geometry.
  • grid_size [Required]
A positive number in Rhino model units for the size of grid cells at which the input _geometry will be subdivided for incident radiation analysis. The smaller the grid size, the higher the resolution of the analysis and the longer the calculation will take. So it is recommended that one start with a large value here and decrease the value as needed. However, the grid size should usually be smaller than the dimensions of the smallest piece of the geometry and context in order to yield meaningful results.
  • offset_dist
A number for the distance to move points from the surfaces of the input _geometry. Typically, this should be a small positive number to ensure points are not blocked by the mesh. (Default: 10 cm in the equivalent Rhino Model units).
  • irradiance
Boolean to note whether the study should output units of cumulative Radiation (kWh/m2) [False] or units of average Irradiance (W/m2) [True]. (Default: False).
  • legend_par
  • cpu_count
  • run [Required]
Set to "True" to run the component and perform incident radiation analysis.
  • points
The grid of points on the test _geometry that are be used to perform the incident radiation analysis.
  • results
A list of numbers that aligns with the points. Each number indicates the cumulative incident radiation received by each of the points from the sky matrix in kWh/m2.
  • total
A number for the total incident solar energy falling on all input geometry in kWh. Note that, unlike the radiation results above, which are normlaized by area, these values are not area-normalized and so the input geometry must be represented correctly in the Rhino model's unit system in order for this output to be meaningful.
  • mesh
A colored mesh of the test _geometry representing the cumulative incident radiation received by the input _geometry.
  • legend
A legend showing the kWh/m2 that correspond to the colors of the mesh.
  • title
  • int_mtx
A Matrix object that can be connected to the "LB Deconstruct Matrix" component to obtain detailed patch-by-patch results of the study. Each sub-list of the matrix (aka. branch of the Data Tree) represents one of the points used for analysis. The length of each sub-list matches the number of sky patches in the input sky matrix (145 for the default Tregenza sky and 577 for the high_density Reinhart sky). Each value in the sub-list is a value between 0 and 1 indicating the relationship between the point and the patch of the sky. A value of "0", indicates that the patch is not visible for that point at all while a value of "1" indicates that the patch hits the surface that the point represents head on.
