Deconstruct Design Day
Deconstruct design day into parameters.
  • design_day [Required]
A DesignDay object to deconstruct.
The name of the DesignDay object.
  • day_type
Text indicating the type of design day (ie. 'SummerDesignDay', 'WinterDesignDay' or other EnergyPlus days).
  • location
A Ladybug Location object describing the location of the design day.
  • date
Date for the day of the year the design day
  • dry_bulb_max
Maximum dry bulb temperature over the design day (in C).
  • dry_bulb_range
Dry bulb range over the design day (in C).
  • humidity_type
Type of humidity to use. Will be one of the following:
  • humidity_value
The value of the humidity condition above.
  • barometric_p
Barometric pressure in Pa.
  • wind_speed
Wind speed over the design day in m/s.
  • wind_dir
Wind direction over the design day in degrees.
  • sky_type
Script output sky_type.
  • sky_properties
A list of properties describing the sky above. For ASHRAEClearSky this is a single value for clearness. For ASHRAETau, this is the tau_beam and tau_diffuse.
