> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/ladybug-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/ladybug-primer/components/2_visualizedata/wind_rose.md). Agents can also search and read this documentation through its [MCP server](https://docs.ladybug.tools/ladybug-primer/~gitbook/mcp).
# Wind Rose
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-0f66efa371078b12443d7e3ddadb57e14383888d%2FWind_Rose.png?alt=media)
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-87637c238a14e1c8cb165b520a24c94ee4c8367c%2FWind_Rose.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/ladybug-grasshopper/blob/master/ladybug_grasshopper/src//LB%20Wind%20Rose.py)
Create a plot of any hourly data by wind directions.
* **north**
An optional number between -360 and 360 for the counterclockwise difference between the North and the positive Y-axis in degrees. 90 is West and 270 is East. This can also be Vector for the direction to North
* **data \[Required]**
A HourlyContinuousCollection or HourlyDiscontinuousCollection of values corresponding to the wind directions, which is "binned" by the direction intervals. This input usually consists of wind speed values, but is not limited to this data type. It can also be a list of data collections in which case multiple wind roses will be output.
* **wind\_direction \[Required]**
A HourlyContinuousCollection or HourlyDiscontinuousCollection of wind directions which will be used to "bin" the \_data items for the windrose.
* **dir\_count**
Number that determines the number of directions to the wind rose will display. The number of directions must be greater then three to plot the wind rose (Default: 36).
* **center\_pt**
Point3D to be used as a starting point to generate the geometry of the plot (Default: (0, 0, 0)).
* **show\_calm**
A boolean to indicate if the wind rose should display the fraction of time with zero wind speed using a circle in the center of the plot. The radius of this circle corresponds to the total amount of time with zero values divided by the number of directions. This means that the time period representing zero values is evenly distrobuted across all directions. (Default: False).
* **show\_avg**
A boolean to note whether the average value in each wind direction bin should be displayed instead of the complete frequency of \_data values. (Default: False).
* **freq\_dist**
The distance for the frequency interval in model units. If show\_calm\_ is True, then the initial frequency interval corresponds to the number of calm hours in the data collection, which may not align with this freq\_dist\_ (Default: 5 meters)
* **freq\_hours**
The number of hours in each frequency interval (Default: 50).
* **max\_freq\_lines**
A number representing the maximum frequency intervals in the rose, which determines the maximum amount of hours represented by the outermost ring of the windrose. Specifically, this number multiplied by the *freq\_hours* parameter will equal the maximum hours in that outermost ring. By default, this value is determined by the wind direction with the largest number of hours (the highest frequency) but you may want to change this if you have several wind roses that you want to compare to each other. For example, if you have wind roses for different months or seasons, which each have different maximum frequencies.
* **legend\_par**
An optional LegendParameter object to change the display of the WindRose plot. The number of segments in the legend determines the number of frequency intervals in the wind rose. If nothing is provided, a default LegendParameter object is computed using values from the wind data with 11 segments (Default: None).
* **statement**
A conditional statement as a string (e.g. a > 25) for the \_data and \_wind\_direction inputs. The variable of the first collection input to \_data should always be named 'a' (without quotations), the variable of the second list should be named 'b', and so on. The wind direction is always the last variable, though most statements won't have a need for it. For example, if three data collections are connected to \_data and the following statement is applied: '18 < a < 26 and b < 80 and c > 2' The resulting collections will only include values where the first data collection is between 18 and 26, the second collection is less than 80 and the third collection is greater than 2.
* **period**
An optional Ladybug analysis period to be applied to all of the input data.
* **mesh**
A colored mesh representing the wind rose derived from the input data. Multiple meshes will be output for several data collections are input.
* **compass**
A set of circles, lines and text objects that mark the cardinal directions in relation to the wind rose.
* **orient\_line**
Line geometries representing the edges (or "spokes") of the wind rose directions.
* **freq\_line**
Polygon geometries representing the frequency intervals of the wind rose.
* **windrose\_line**
Polygon geometries representing the windrose outlines. This output is hidden by default and should be connected to a native Grasshopper Geometry component in order to be visualized.
* **legend**
Geometry representing the legend for the wind rose.
* **title**
A text object for the global\_title.
* **prevailing**
The predominant direction of the outpt wind rose in clockwise degrees from north. 0 is North, 90 is East, 180 is South, 270 is West.
* **angles**
A list of angles corresponding to each windrose directions.
* **calm\_hours**
The number of hours with calm wind speeds. Only returns a value if the input \_data is wind speed.
* **histogram**
The input \_data in a histogram structure after it has gone through any of the statement or period operations input to this component.
* **vis\_set**
An object containing VisualizationSet arguments for drawing a detailed version of the Wind Rose in the Rhino scene. This can be connected to the "LB Preview Visualization Set" component to display this version of the Wind Rose in Rhino.
