Get Grids and Views
Get Radiance Sensor Grids and/or Views from a Honeybee Model and visualize them in the Rhino scene.
A Honeybee Model for which grids and views will be output.
Text for a view identifer or a pattern to filter the views of the model that are output. For instance, first_floor_* will simulate only the views that have an identifier that starts with first_floor_. By default, all views in the model will be output.
Text for a grid identifer or a pattern to filter the sensor grids of the model that are output. For instance, first_floor_* will simulate only the sensor grids that have an identifier that starts with first_floor_. By default, all grids in the model will be output.
A list of Honeybee-Radiance Views that are assigned to the input _model.
A list of Honeybee-Radiance SensorGrids that are assigned to the input _model.
The points that are at the center of each grid cell.
Mesh for each sensor grid, which can be passed to the "LB Spatial Heatmap" component.
