Glass Modifier
Create an glass radiance modifier from a single transmittance.
A number between 0 and 1 for the glass modifier transmittance. This transmittance will be the same for the red, green and blue channels.
Index of refraction. Typical values are 1.52 for float glass and 1.4 for ETFE. If None, Radiance will default to using 1.52 for glass (Default: None).
A glass modifier that can be assigned to a Honeybee geometry or Modifier Sets.
