> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-radiance-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-radiance-primer/components/1_modifiers/translucent_modifier.md).
# Translucent Modifier
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-a5812fd922cb264c23f20a12ed78c6fe89d8d13f%2FTranslucent_Modifier.png?alt=media)
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-210be64cc39c3545d4c4fa4c9a4be96cdef2be26%2FTranslucent_Modifier.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-radiance/blob/master/honeybee_grasshopper_radiance/src//HB%20Translucent%20Modifier.py)
Create a translucent radiance modifier from a reflectance and transmittance.
The sum of the reflectances and transmittances must be less than 1 and any energy not transmitted or reflected is assumed to be absorbed. The resulting material will always be grey with equivalent red, green and blue channels.
* #### name
* #### diff\_ref \[Required]
A number between 0 and 1 for the diffuse reflectance of the material.
* #### diff\_trans \[Required]
A number between 0 and 1 for the transmitted diffuse component. This is the fraction of transmitted light that is diffusely scattered.
* #### spec\_trans
A number between 0 and 1 for the transmitted specular component. This is the fraction of transmitted light that is not diffusely scattered but passes through like a beam. (Default: 0).
* #### spec
A number between 0 and 1 for the fraction of specularity. Specularity fractions greater than 0.1 are not common in non-metallic materials. (Default: 0).
* #### rough
Roughness is specified as the rms slope of surface facets. A value of 0 corresponds to a perfectly smooth surface, and a value of 1 would be a very rough surface. Roughness values greater than 0.2 are not very realistic. (Default: 0).
* #### modifier
A translucent modifier that can be assigned to a Honeybee geometry or Modifier Sets.
