Subface Modifier Subset
Create a list of exterior subface (apertures + doors) modifiers that can be used to edit or create a ModifierSet object.
  • window
A modifier object for apertures with an Outdoors boundary condition and a Wall face type for their parent face. This can also be text for the identifier of the modifier within the library.
  • skylight
A modifier object for apertures with an Outdoors boundary condition and a RoofCeiling or Floor face type for their parent face. This can also be text for the identifier of the modifier within the library.
  • operable
A modifier object for apertures with an Outdoors boundary condition and True is_operable property. This can also be text for the identifier of the modifier within the library.
  • exterior_door
A modifier object for opaque doors with an Outdoors boundary condition and a Wall face type for their parent face. This can also be text for the identifier of the modifier within the library.
  • overhead_door
A modifier object for opaque doors with an Outdoors boundary condition and a RoofCeiling or Floor face type for their parent face. This can also be text for the identifier of the modifier within the library.
  • glass_door
A modifier object for all glass doors with an Outdoors boundary condition. This can also be text for the identifier of the modifier within the library.
  • subface_set
A list of exterior subface modifiers that can be used to edit or create a ModifierSet object.
