Opaque Modifier
Create an opaque radiance modifier from a single reflectance.
A number between 0 and 1 for the absolute diffuse reflectance of the modifier. This reflectance will be the same for the red, green and blue channels.
A number between 0 and 1 for the absolute specular reflectance of the modifier. Note that the sum of this value and the diffuse _reflect should be less than one. Specular reflectances greater than 0.1 are rare for non-metallic materials. (Default: 0).
Roughness is specified as the rms slope of surface facets. A value of 0 corresponds to a perfectly smooth surface, and a value of 1 would be a very rough surface. Roughness values greater than 0.2 are not very realistic. (Default: 0).
An opaque modifier that can be assigned to a Honeybee geometry or Modifier Sets.
