Opaque Modifier 3
Create an opaque radiance modifier from red, green, and blue reflectances.
A number between 0 and 1 for the absolute diffuse red reflectance.
A number between 0 and 1 for the absolute diffuse green reflectance.
A number between 0 and 1 for the absolute diffuse blue reflectance.
A number between 0 and 1 for the absolute specular reflectance of the modifier. Note that the sum of this value and the diffuse should be less than one. Specular reflectances greater than 0.1 are rare for non-metallic materials. (Default: 0).
Roughness is specified as the rms slope of surface facets. A value of 0 corresponds to a perfectly smooth surface, and a value of 1 would be a very rough surface. Roughness values greater than 0.2 are not very realistic. (Default: 0).
An opaque modifier that can be assigned to a Honeybee geometry or Modifier Sets.
