Model to Rad Folder
Write a Honeybee Model to a Radiance Model Folder.
This Radiance Model Folder is what is used to run various types of Radiance studies off of a consistent set of geometry and modifiers.
A honeybee model object possessing all geometry, radiance modifiers and simulation assets like Sensor Grids and Views.
Boolean to note whether the radiance strings should be written in a minimal format (with spaces instead of line breaks). (Default: False).
Path to a folder to into which the Model Radiance Folder will be written. If unspecified, it will be written to a sub-folder within the default simulation folder.
Set to True to write the Model to a Radiance folder.
Path to the folder in which all of the files have been written.
