Metal Modifier 3
Create a metal radiance modifier from red, green, and blue reflectances.
  • r_diff
A number between 0 and 1 for the absolute diffuse red reflectance. (Default: 0).
  • g_diff
A number between 0 and 1 for the absolute diffuse green reflectance. (Default: 0).
  • b_diff
A number between 0 and 1 for the absolute diffuse blue reflectance. (Default: 0).
  • spec
A number between 0 and 1 for the absolute specular reflectance of the modifier. Note that the sum of this value and the diffuse should be less than one. Specularity of metals is usually 0.9 or greater. (Default: 0.9)
  • rough
Roughness is specified as the rms slope of surface facets. A value of 0 corresponds to a perfectly smooth surface, and a value of 1 would be a very rough surface. Roughness values greater than 0.2 are not very realistic. (Default: 0).
  • modifier
A metal modifier that can be assigned to a Honeybee geometry or Modifier Sets.
