> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-radiance-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-radiance-primer/components/4_results/extract_hdr.md). Agents can also search and read this documentation through its [MCP server](https://docs.ladybug.tools/hb-radiance-primer/~gitbook/mcp).
# Extract HDR
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-5199e47f120b888a2d9e2e9e1b567728ae7acb66%2FExtract_HDR.png?alt=media)
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-5581a7597ce753b379c5d7917c222691bd92eb91%2FExtract_HDR.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-radiance/blob/master/honeybee_grasshopper_radiance/src//HB%20Extract%20HDR.py)
Interpolate or extrapolate a High Dynamic Range (HDR) image file from another HDR image file.
Recommended use is to extract 180 FOV (-vh 180 -vv 180) angular or hemispherical HDR images from a 360 FOV (-vh 360 -vv 360) angular HDR image. Alternatively, conversions between 180 FOV angular and hemispherical HDR images can be made.
* #### view \[Required]
A view to interpolate or extrapolate into a new HDR. The "HB View" component can be used to create an input view and it must have the same position as that use to make the \_hdr.
* #### hdr \[Required]
Path to a High Dynamic Range (HDR) image file from which to interpolate or extrapolate.
* #### resolution
An integer for the dimension of the output image in pixels. If extracting a 180 FOV angular or hemispherical HDR image from a 360 FOV HDR image, the default resolution is 1/3 of the resolution of \_hdr. If converting between 180 FOV angular or hemispherical HDR images, the default resolution is that of \_hdr.
* #### hdr
Path to the resulting HDR image file.
