> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-radiance-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-radiance-primer/components/4_results/annual_glare_metrics.md). Agents can also search and read this documentation through its [MCP server](https://docs.ladybug.tools/hb-radiance-primer/~gitbook/mcp).
# Annual Glare Metrics
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-4a969f060e7758c7455d8404029d1058fb55dc5a%2FAnnual_Glare_Metrics.png?alt=media)
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-8cee1ff5312b2e56d1617ac124662a836cedb2ea%2FAnnual_Glare_Metrics.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-radiance/blob/master/honeybee_grasshopper_radiance/src//HB%20Annual%20Glare%20Metrics.py)
Calculate Annual Glare Metrics from result (.dgp) files.
Glare Autonmy is a metric describing the percentage of occupied hours that each sensor is below the glare threshold.
Spatial Glare Autonomy is a metric describing the percentage of the sensor grid that is free glare according to the glare threshold and the target time. The sGA value is expressed as a percentage of the sensors in the analysis grid.
* #### results \[Required]
An list of annual Radiance result files from the "HB Imageless Annual Glare" component (containing the .dgp files and the sun-up-hours.txt). This can also be just the path to the folder containing these result files.
* #### occ\_sch
An annual occupancy schedule as a Ladybug Data Collection or a HB-Energy schedule object. This can also be the identifier of a schedule in your HB-Energy schedule library. Any value in this schedule that is 0.1 or above will be considered occupied. If None, a schedule from 8AM to 6PM on all days will be used.
* #### glare\_thresh
Threshold for glare autonomy (GA) in DGP (default: 0.4).
* #### grid\_filter
The name of a grid or a pattern to filter the grids. For instance, first\_floor\_\* will simulate only the sensor grids that have an identifier that starts with first\_floor\_. By default all the grids will be processed.
* #### target\_time
A minimum threshold of occupied time (eg. 95% of the time), above which a given sensor passes and contributes to the spatial glare autonomy. (Default: 95%).
* #### report
* #### GA
Glare autonomy results in percent. GA is the percentage of occupied hours that each sensor is free of glare according to the glare threshold. Each value is for a different sensor of the grid. These can be plugged into the "LB Spatial Heatmap" component along with meshes of the sensor grids to visualize results.
* #### sGA
Spatial glare autonomy as a percentage of the sensors for each analysis grid that does not exceed the glare threshold for a specified fraction of occupied hours, ie. the target time.
* #### pass\_fail
A data tree of zeros and ones, which indicate whether a given sensor passes the criteria for being free of glare (1) or fails the criteria (0). Being free of glare does not necessarily mean that the sensor is glare-free for all hours, but that it is glare-free for a minimum percentage of occupied hours defined by the target time. Each value is for a different sensor of the grid. These can be plugged into the "LB Spatial Heatmap" component along with meshes of the sensor grids to visualize results.
